Automatic trans.
Old Nov 25, 2009 | 10:59 AM
Laco's Avatar
Synthetic or not, I would still be more comfortable checking it at regular intervals. I have a huge diesel RV with an Allison six speed transmission, filled with synthetic. Though the change cycle is 100,000 miles, it does have a dip stick for checking at least every time the vehicle is serviced.
Old Nov 25, 2009 | 05:06 PM
jay loukakis's Avatar
Originally Posted by oneton
Do you have over 100,000m on your 06 HHR or are you having a prob. with it?
If no to ? then why are you changing it
changeing trans. fluid on my auto, the book says to change at 50,000 miles I have a little over 41,000 had it checked everything ok just wanted to be ready, the trans shop i had check it said everything is OK that is when I found out you have to go to the chevy dealer, i mhad a problum with the traction control was on but that got fixed for $25.00.
Old Nov 25, 2009 | 11:43 PM
From my 08 Owners Manual, 50K change (Severe Service only). See footnote (h)
section 6, page 8.
Change automatic trans fluid & filter if..........
- In heavy city traffic where outside temp regularly reaches 90*F
- In hilly or mountainous terrain
- When doing frequent trailer towing
- Uses such as found in taxi, police or delivery
If not, it does not require changing.
PS: I'll be changing mine at 50K anyway. Syn Fluid is much cheaper than a tranny..
Old Nov 26, 2009 | 11:47 PM
IgottaWoody's Avatar
Hmmmm.... frequent trailer towing....
Old Nov 30, 2009 | 07:22 PM
uncle_zah's Avatar
I agree with you Sno White. Like SSguy its in the manual
-In heavy city traffic where outside temp regularly reaches 90*F-
-In hilly or mountainous terrain-I live in Texas hmmm this concerns me. Im like some of you guys with or without a dipstick I still want to know fluid level. There is a cap on top move the wires over and you will see it. Its the path flow of wires between the engine and fuse box area. On the bottom a small screw same side as the torque converter is on. And of course there is a drain plug. I've got to get a camera.
deve
May 28, 2015 08:54 AM
pro50stude
Nov 17, 2014 12:57 AM
Cat Man HHR
Nov 16, 2014 07:44 AM
MOTRV8D
Nov 10, 2007 03:02 PM
misterjensen
Jul 25, 2007 04:33 PM
