Bad oil change experience.
Old Mar 17, 2008 | 08:49 AM
wingfeather's Avatar
Originally Posted by prod
Havent tried it myself, but sounds like you need one of these these:
What GM should've done is just build the socket adapter into the lid. That way, you just snap in your 3/4" extension & turn
Originally Posted by Armadillo
The old filter had plenty of metal shavings in it, some relatively big. I was shocked.
This is what scares me about going over 500 miles on the first oil change. I'm at 1800 miles & think I'll get mine done this weekend. The first change is sooooo VITAL due to metal particles sandblasting the engine.
Old Mar 23, 2008 | 02:27 PM
Armadillo's Avatar
Originally Posted by an08HHR
I may order one from Sears. They have one for 10 bucks, which looks real short. KD Tools 32 mm Oil Filter Cap wrench, Sears # 0099642000
model # KD3932.
Thank you thank you thank you an08HHR.
I ordered one of those Sears sockets and it works great. I tried it out today and it has plenty of clearance.
One more observation. I put in a Fram filter this time. The NAPA I put in before was still new, but I didnt know if it would seal if I re-used it.
I compared the Fram to a SuperTech. I thought the SuperTech was the same as Fram (same number) but the SuperTech was the same design as NAPA (Wix). Maybe SuperTech buys from whoever gives it the best deal on bulk?
Old Apr 6, 2008 | 08:06 PM
Biff's Avatar
Ok,
how the heck do you order part number # 0099642000?
I have been to their website and didn't get any where searching on that part number, and the 32mm sockets I did find -
had different part numbers (and were much more expensive).
I tried a google search for 'sears' and this part number - and it just leads me back to this topic ;-)
I have everything I need for my first oil change - except the socket...
Old Apr 6, 2008 | 09:15 PM
an08HHR's Avatar
Originally Posted by Biff
Ok,
Go to sears.com and in the search window just type in oil filter socket wrench and you will find it.
Old Apr 6, 2008 | 09:56 PM
Goose's Avatar
Just go to AutoZone or any parts store and get a 1 1/4 socket for like 6 bucks and you are in business
Goose
Old Apr 6, 2008 | 09:58 PM
  #26
Cyclic Hardover's Avatar
I haven't gone looking for this yet on my 2.4. Filter and a socket? is the filter just hanging off like every other "normal' car or is it going to be an airfilter nightmare
Old Apr 6, 2008 | 10:50 PM
  #27
Silentgarth's Avatar
Here are some pictures. I'm sure that most of you know were this stuff is but for the uneducated. The socket I bought at PepBoys. But you should find it at AutoZone, Advanced, Checkers, Oriley's, etc... And these pics are form my 06 cobalt, hence the yellow.
Here are two pictures so you can see what it looks like:
The black cap that has the two silver dots on it is the oil filter cap.
I like to use two extensions(these are all I have right now). It takes the wrench up high so no banged up knuckles.
Hope this helps.
Old Apr 7, 2008 | 04:02 AM
  #28
Goose's Avatar
So easy a caveman could do it!
Goose
Old Mar 30, 2009 | 07:30 AM
  #29
Smallblock's Avatar
Crap.. wish i would have found this topic before I had my socket problem.I thought I planned ahead and went to sears and bought a 32mm.. Needless to say it didn't work on our 2.4. I ended up using a cresent wrench also.
Old Mar 30, 2009 | 08:24 AM
  #30
esmarkey's Avatar
The key is to have a SHORT 32mm socket. Several people have cut down standard sockets and that works fine if you don't get the "special" socket for oil filters.
Also, this socket works on all the Ecotechs, including the 2.0
Since this thread has been bumped from last year, it is good info for new members.
JWA
16
Jun 21, 2014 12:16 PM
badassbowtie
Maintenance and Upkeep
23
May 12, 2013 02:01 PM
yellowjacket
2.2L Performance Tech
12
Jul 6, 2012 03:47 AM
1HotHHR
Sep 15, 2007 09:55 AM
jayras
Jul 4, 2006 11:33 AM
