Battery light stuck on
Old 05-14-2018, 04:37 PM
hurst2001's Avatar
Ok guys got a 2007 with about 258000 and my wife hit a bump and light came on .. there are no messages no check engine light just battery .. possible alternator going or what the best way to check it thanks
hurst2001 is offline
Old 05-14-2018, 04:56 PM
Let the auto parts store test your battery and charging system.
Inspect the serpentine belt.
See if the battery connections in the back and at the fuse block are tight and clean.
RJ_RS_SS_350 is offline
Old 05-14-2018, 06:07 PM
hurst2001's Avatar
ok went to autozone and they tell me the battery is at 74 percent .. so I went to test with the meter car off it at 12.58 with everything on it was at 10.88 so I’m guessing got to be the alternator not charging?
Old 05-14-2018, 06:36 PM
You didn't have them test the charging system?
The battery might be bad.
Old 05-14-2018, 06:42 PM
Did you look and see if the serpentine belt is there ?
Like RJ stated. If you went to AZ, you should have had them check the entire charging system, including the battery.
firemangeorge is online now
Old 05-14-2018, 06:56 PM
hurst2001's Avatar
well girl tells me that she can’t because the battery is weak I’m like really .. the place is useless I told her to check the alternator but that’s what I get ..and yes the serpentine is there .. and seen a liitte smoke rising in that area .. I mean 258000 on the original alternator is pretty good I think ..
Old 05-14-2018, 08:23 PM
A little smoke in that area, you mean the alternator? It could be it’s cooking out!
Oldblue is online now
Old 05-14-2018, 08:29 PM
True they can't check the alternator with a dead battery.
From your description of the onset, my guess would be a loose wire.
donbrew is offline
Old 05-14-2018, 08:44 PM
hurst2001's Avatar
the battery tested at 74 percent when I put a load on it everything on it drop 10.88 .. all I seen some smoke coming from the alternator area so I shut the car off .. so I feel that the brushes in alternator seen better days.. the car starts right up so I not sure but I will take to a shop I that I trust to see what’s the deal ..
Old 05-15-2018, 08:33 AM
12.0 V is dead.
Electrical equipment won't work without the magic smoke, once it is released there is no hope.
donbrew is offline
Quick Reply: Battery light stuck on
