Black front pad
Old Nov 22, 2009 | 04:44 PM
gravett1's Avatar
Question Black front pad
Has anyone painted the black part of the front bumper cover? IF so how did you prep, got hit while parked Friday night , so I thought might color match the pad.
Old Nov 22, 2009 | 07:03 PM
djr1973's Avatar
I have also thought about doing the same thing to mine, i know being plastic you will need flexible primer. not sure on the prep though or exactly what all you will need to do it.
Old Nov 22, 2009 | 07:24 PM
wagoneer's Avatar
I saw a post a while back where someone paint matched it. It looked really good
Old Nov 23, 2009 | 01:41 PM
Personally, I would add "Flex-agent" to primer, base color & clear coat.
Old Nov 24, 2009 | 07:30 AM
garagebuilt's Avatar
i sanded mine with 80 grit cleaned it with wax/ grease remover and primed it with urethane 2k then blocked it like you would anything else. my opinion is that you wont need flex agent. i twisted mine after a few coats of primer and it didnt crack. this part shouldnt see much flex unless it gets hit again.
Frozenspokes
7
Aug 21, 2007 12:51 AM
