Brake fluid indicator on unit
Old Mar 5, 2019 | 04:43 PM
hurst2001's Avatar
Just like it say we’re the hell is it at ? All I can see is a a little small circle above the two parts were the reserve meets togather .. just try to see we’re my level of brake fluid is at .. thanks
Old Mar 5, 2019 | 07:13 PM
See just back there above the mould line, by the black wire loom, there is the MIN indicator
Old Mar 5, 2019 | 07:28 PM
hurst2001's Avatar
right we’re the rigid curves ?
Old Mar 5, 2019 | 08:32 PM
Yep, right there. back left side, as you look at it. .. Look closer. Move the wiring corrugated covering, if you need to.
And Max full mark is about 1 inch above it.
Old Mar 5, 2019 | 10:29 PM
hurst2001 ( it's spelled WHERE)
FYI. You shouldn't be adding brake fluid unless you have a leak or are doing a fluid flush.
The fluid level will show lower as the brakes wear. If you fill the reservoir to the top with worn brakes, you're in for a big mess when you do the next brake job.
(ex: retracting the calipers to replace pads forces fluid back into the reservoir. If it's been filled too much, you're going to push brake fluid out the top and have a big spill)
glenngeb
Feb 4, 2019 03:56 PM
Rjj
Oct 22, 2017 08:56 AM
bad03xtreme
Maintenance and Upkeep
13
Dec 19, 2014 06:23 PM
John Lupanoff
Jan 4, 2010 01:34 PM
