Car will not start after battery removal.
Old Jan 24, 2025 | 12:19 PM
jd_boggs@yahoo.com's Avatar
I will pull the ecu and inspect the pins etc...
Old Jan 24, 2025 | 01:00 PM
I pulled the ecu, inspected the pins and there are no bent pins at all.....
Old Jan 24, 2025 | 01:26 PM
Any pins pushed out the back? Like loose.
Did you check the battery connections (they should not be loose enough to twist by hand) and the fuse near the battery ground?
Gremlins; Did you feed them after midnight?
Old Jan 24, 2025 | 01:49 PM
thanks don found the problem with your input.... now I can go back and fix the real problem with o2 sensor.... stick around you might fix the next issue!!!
Old Jan 24, 2025 | 01:54 PM
What was it?
Old Jan 24, 2025 | 06:04 PM
  #26
Originally Posted by donbrew
What was it?
OK, found my problem that I was getting communication error codes when trying to read OBD codes. I did NOT have the tranmission plug all the way locked in. Once I corrected that I could read the codes but got "BRAKE" light is left on. Will deal with that later. But thank you all for your ideas. Someone posted to check for bent pins that's what lead me to the unlocked connector..... my bad
Old Jan 25, 2025 | 08:21 AM
  #27
You are welcome.
Old Jan 25, 2025 | 09:24 AM
  #28
What does that mean?
Old Jan 25, 2025 | 10:36 AM
  #29
parking brake lever was left ON
Old Jan 25, 2025 | 11:31 AM
  #30
A code reader reported that? What is to be dealt with? I don't understand anything about the comment.
Very poor practice to use code reader definitions instead of OBD code numbers. Every code reader has a different translation from English to Korean to Mandarin back to English.
