Charging a dead battery
Old Oct 26, 2009 | 06:03 PM
Laco's Avatar
Originally Posted by Czechman
Is there any logic behind not using the grounding stud? Seems odd to bypass something so clear and obvious in favor of something, anything else.
I was told by the service manager at the local dealer, they had replaced a number of damaged struts, he said as a result of using it as a ground for jump starting. It got kind of controversial on one of these threads, but in my mind, better safe than sorry, and its really no big deal to do, so since there is certainly no harm using the block as a ground, I will continue to do so.
Old Oct 26, 2009 | 07:57 PM
Snoopy's Avatar
Laco......
And I trust, the Service Manager notified GM of the replacement, do to what he concluded, was a defect. At least that is what he is required to do.
And, let's see........no TSB or Bulletins, or correction mailings to Owners, or anything, from GM/Chevrolet regarding this "problem"......hmmmmmm.
Old Oct 27, 2009 | 04:07 PM
Laco's Avatar
As I said, it became controversial, but its so easy to clamp onto the block, its just not a big deal. I have no way of knowing how true this is, or what the rate of occurance may or may not be, but why would he lie? At any rate, as I said, I have never had any problem charging, using the connector(s) under the hood.
Old Oct 27, 2009 | 07:19 PM
Czechman's Avatar
The important thing that's come from all of this is that you charge the battery from under the hood, not directly to the battery.
kmcrae476
May 25, 2015 11:19 PM
ET1BOOKER
May 6, 2015 07:25 AM
longhornss
Feb 27, 2009 01:15 PM
ICUFOS
2.2L Performance Tech
Feb 2, 2008 09:42 PM
harleyfxd
Sep 16, 2007 08:45 PM
