Code P0128
Old Apr 18, 2018 | 04:29 PM
Originally Posted by donbrew
Just woke up from nap
Well, good morning!
Old Apr 18, 2018 | 05:54 PM
fasteddy530's Avatar
Originally Posted by Ryan Luttio
Is it possible for the temp read out to be working, but the thermostat still be bad? My 06 2.2 threw this code, and besides running about 10º cooler then normal, all the readouts seem fine.
From my experience if the car doesn't hit 180 degrees within a specified time it will turn the check engine light on. After I replaced my thermostat with the A/C Delco 131-158 it's been fine! Apparently this engine is very finicky when it comes to thermostats!
Old Mar 17, 2023 | 01:24 PM
top_prop's Avatar
Got the subject code... Temp needle went to zero. Temp readout on the cluster went to - - -. Checked temp sensor connection and kept driving. Eventually the temp readings came back and the mil would reset/codes clear. Temp Stayed in the high 190's but peaked at 205 and low of 192. Ambient tempt of 44f. Mil stayed off
Parked it over night.
Put in my BlueDriver and pulled live data from a cold start... 35deg f external temp matched start temp readings. The engine only warmed to about 166f while driving... Then the temp needle went back to nil and the dash read - - -. Live data continued to show temp in The mid 160's.
Parked and let it idle... Still nil and dashes but live data rose to 178f. Will check for air... But it looks like the thermostat stuck open (due to temp readings via live data) and the computer puts these to nil on needle and dashes if it doesn't see a steep enough rise (from my experience and posts here this jibes).
Wierd. I'd think it would be more valuable to have the ability to monitor the collant temp via the instrument cluster... Why not just throw the code and turn on The mil... Why kill the temp reading?
Hope this helps.
Old Mar 17, 2023 | 02:01 PM
The reason it goes flat is that most drivers completely ignore things. So, GM throws more hints.
Your high temps are a little high, not worrisome but deserves looking into.
Obviously the temp will rise while idling; the fan does not turn on until 217F and no air flow while sitting still.. Then it turns off at 180F.
Use ONLY ACDelco 131-158, not "like" or "replaces" or any other part number. Experience shows others fail.
Old Mar 17, 2023 | 02:43 PM
X2 don’t even get the AC Delco professional thermostat, you’re wasting time and money, ask me how I know!
Old Mar 17, 2023 | 03:15 PM
  #26
That's a lot of wasted typing... reading the thread would have given you the answer.
Old Mar 17, 2023 | 03:18 PM
  #27
For a future reader that might not go back to first page
KrazyKim
Jul 4, 2022 01:36 PM
jima70
Oct 26, 2021 04:41 PM
Tydog
Jul 27, 2017 08:14 AM
quicksilver58
Dec 2, 2015 08:43 PM
tracy waddell
Jan 9, 2011 10:49 AM
