? Tie rods
Old Mar 13, 2023 | 09:32 AM
Gearhead1's Avatar
? Tie rods
I have 2011 hhr LT 2.2 and I want to order tge correct inner and outer tie-rods….how do I tell which suspension package this thing has?
Old Mar 13, 2023 | 09:45 AM
Look at the glovebox RPO sticker. It will be either the FE1 or FE3. A 2011 model with the base 2.2L engine most likely is the FE1 suspension.
Old Mar 13, 2023 | 09:49 AM
Gearhead1's Avatar
Tie rods…
ok thanks….says FE1
Are the inner ones as much fun to change as Im expecting? Any Idea what they torque to?
Old Mar 13, 2023 | 11:56 AM
74 ft lbs
https://chevy-specs.com/cars/2008/hh...pecs_front.php
Old Mar 15, 2023 | 06:37 AM
PulpFriction's Avatar
The FE3 has different tie rods???
Old Mar 15, 2023 | 06:44 AM
No, they are the same as FE1
Old Mar 18, 2023 | 12:15 AM
Right. As far as I can tell, the only difference between FE1 & FE3 is dampeners. Still trying to figure out what differences there might be in springs between years or wagon vs. panel.
Old Mar 18, 2023 | 07:32 AM
Part numbers way back when these were new, but those are long obsolete and most aftermarket companies just make a spring more FE3 then FE1.
tiapetra
May 12, 2020 10:00 AM
davidfr
Maintenance and Upkeep
Jun 15, 2019 07:26 PM
McB_HHR
Apr 11, 2017 04:33 PM
EZDAY
May 22, 2016 07:08 PM
hhrlover101
Sep 6, 2012 06:06 PM
