Door Question
Old Mar 7, 2017 | 11:45 AM
Ron S's Avatar
Door Question
I noticed a hole in the door when it was opened on my wife's 09. It is located at the end of the door handle. On my 10 there is a reflective adhesive disc at this location. On the other three doors on both cars there is a rubber plug. Does anyone know what is supposed to be there?
Thanks
Ron
Old Mar 7, 2017 | 11:56 AM
Cat Man HHR's Avatar
Thanks
Ron
I too noticed that when I changed my door handles. More than likely it should have had a rubber plug also. I guess it just wasn't installed and reflective tape was put over the hole. That's my best guess.
Now that you brought it up it bugs me and have to get a plug for the hole.
Old Mar 7, 2017 | 12:06 PM
In the drivers door, a small round red reflective sticker is supposed to be there.
If the outer handle has been changed or serviced then you could stop by any parts palace and get a rubber plug to fit the hole.
I used one of the plugs from a rear door , I got at a dismantling yard.
Old Mar 7, 2017 | 12:27 PM
The reflective bit is actually a safety thing as well as a hole cover. It covers the access to the door handle bolt.
They were available from GM last time I looked.
Old Mar 7, 2017 | 02:31 PM
My red reflective sticker has a hole punched in it... Not doing much good that way.
Leonard
May 29, 2012 10:34 AM
WhiplashHHR
Nov 27, 2007 08:01 PM
giant96
Feb 28, 2007 02:34 PM
wolfee
Oct 25, 2006 02:18 PM
