Dual exhaust
Old Aug 19, 2009 | 09:12 AM
solman98's Avatar
Originally Posted by unique_w
There may be a slight difference between the manual and automatic trans near the catalytic converter but the remained appears similar.
Not sure there is enough room between what looks like a resonator and the rear beam for a Camaro style muffler, unless it was very small. Did this on my GMC Sonoma V6 but there was plenty of room.
I was referring to running the muffler along side the rear beam after the exhaust goes over the rear beam Just have it turn in to the inlet, and out each outlet to the rear.
The only part to change would be after the beam, nothing before.
Old Aug 19, 2009 | 10:39 AM
This is basically the same way PT Bob routed his. The heat shield on the crossing pipe is a nice touch. Great pics.
Old Aug 19, 2009 | 10:49 AM
unique_w's Avatar
Camaro Muffler
Originally Posted by solman98
I was referring to running the muffler along side the rear beam after the exhaust goes over the rear beam Just have it turn in to the inlet, and out each outlet to the rear. The only part to change would be after the beam, nothing before.
I think you are referring to directly below the gas tank, it may hang too low for clearance purposes. Take notice of the heat shield used on the cross pipe behind the rear beam in the prior pics.
Old Aug 19, 2009 | 11:15 AM
solman98's Avatar
I saw the heat shield. Something similiar could be done to a muffler. Just a thought for someone wanting to add that second tip.
And isn't the gas tank in front of the axle beam, not behind?
Old Aug 19, 2009 | 02:39 PM
GTOMIKE's Avatar
Originally Posted by Senior
Do you think the Volt will come with duals?
No but it will be real easy
Old Aug 19, 2009 | 04:19 PM
  #26
1Panel2NV's Avatar
Yes it is. It's underneath the rear seat basically. The way mine is, it's close to the EVAP system and the fuel filler tube, that's why I used the heat shield. I have had my exhaust tips moved in a few inches since those pictures by the way.
hotrodharley
2.2L Performance Tech
14
Oct 6, 2014 02:31 PM
RobPerdue
Mods - Engine/Exhaust
16
Jun 28, 2012 04:44 PM
capp002
May 5, 2011 09:44 AM
itschaboykenny
Mar 20, 2008 08:30 AM
Lee3333
2.4L Performance Tech
20
Aug 9, 2006 10:31 AM
