enter into cooling mode
Old May 19, 2023 | 11:04 AM
Have you looked at the coolant level under the pressure cap?
Does the cooling fan run, starting at about 219F?
If the fan does run and the coolant is full then the water pump must be bad.
If the engine is also vibrating like crazy the balance shaft chain is broken.
The warning gets displayed at around 250F, that is when internal damage starts and the Dexcool is degraded and needs to be replaced..
The Owner Manual tells you how to read the digital coolant temperature. The gauge on the dash is useless.
Old May 19, 2023 | 01:15 PM
WoodysMobile's Avatar
The preceding post is pure useful gold nugget analysis.
If donbrew went any further and looked under the hood, it would be the one hour minimum diagnostic fee$!
All you need to do is respond with your results. Good luck.
Old May 19, 2023 | 02:04 PM
alvindw25's Avatar
thanks i will check the water pump
Old May 19, 2023 | 02:31 PM
Just look up under the passenger side behind the front tire look for any coolant leaking
Phillymanic
Dec 29, 2022 07:54 AM
strongvoice1
Sep 19, 2019 10:47 PM
racing123
Oct 6, 2017 07:00 PM
Wirewoman
Maintenance and Upkeep
7
Jul 23, 2017 03:43 PM
Coffan
May 16, 2016 03:33 PM
