first gear don't engage first time, but the second to the first yes
Old Nov 15, 2022 | 10:15 PM
greg8453's Avatar
Not on my SS. Do that “clutchless thing” and you’ll grind the gears. I’ve tried it several times before but it always grinds.
I’ve driven many vehicles over the years that you could use that clutchless technique. My SS is one that you can’t.
Regardless he needs to see if it does if in other gears.
Old Nov 16, 2022 | 05:50 AM
PulpFriction's Avatar
Originally Posted by donbrew
My money is on the clutch not fully disengaging. Probably a mechanical issue between the pedal and the MC. Since there is no adjustment I think the MC might be misaligned or loose, not letting the plunger go all the way in. Or, wrong MC.
This. Or a dragging TB. Or worn synchro due to all the other problems.
i habitually shift to second and then to first. Maybe even run through 4-3-2-1 when the car is cold. Have done so since I began doing it when I was learning to drive at age 15. May 5th before reverse, too. Think I have drive cars that didn’t even have syncro in 1st and reverse.
Also, give it a second between pushing in the clutch and shoving it into 1st.
Just random thoughts. I’m not really awake yet.
fastsuv
Drivetrain (Excluding Engine)
15
Oct 19, 2017 11:12 AM
skyline26
Sep 9, 2013 03:34 PM
bad03xtreme
Aug 14, 2009 07:03 PM
SSilverbullet
Mar 25, 2009 05:48 PM
Lone Ranger
Aug 15, 2008 09:17 AM
