Question on "I" gear on the automatic transmission
I'm not sure if it ever did this before or not, because only time I used "I" gear much was for downhill. But on mine I notice that on acceleration it holds 2nd gear until 4000rpm regardless of type of acceleration (spirited or normal/easy). Is this normal for "I" ?
Yes, do a search - there was a big thread on this about 6 months ago - covers everythings to be said about the I gear. I kind of liken it to starting out in 2nd gear to get out of snow, mud without spinning the wheels, but it does seem to have a fun feeling to it when driving. I suspect you are using a ton more of gas however - watch how high it revs, as you are eliminating the overdrive aspect of the car.
roadblock69
Drivetrain (Excluding Engine)
14
Aug 24, 2024 09:42 AM
BlackHHR Music Machine
2.4L Performance Tech
78
Mar 28, 2015 06:07 PM
