Flex pipe….
Old Sep 23, 2024 | 07:01 AM
Gearhead1's Avatar
Flex pipe….
Can a bad, leaking flex pipe cause hhr to run hotter?
Old Sep 23, 2024 | 07:16 AM
It’s possible, because the computer is seeing different parameters for air fuel mixture
Old Sep 23, 2024 | 07:54 AM
PulpFriction's Avatar
Much more likely that it’s something wrong with the cooling system. Definitely eliminate that before you start looking for longshot reasons.
Maybe you should tell us about the overheating.
Old Sep 24, 2024 | 11:12 AM
WoodysMobile's Avatar
Hotter = how much so? A few degrees or enough to set idiot light type overheating.
In theory exhaust maybe diluted a bit lean causing computer to a richer mixture than necessary, more fuel more heat.
un-burned fuel in converter it needs to work harder
Basics first on the checklist.
Gearhead1
Nov 20, 2024 11:58 AM
Sillyrabbitgirl
Jul 30, 2024 07:36 PM
Twon
Maintenance and Upkeep
11
Jun 6, 2016 04:01 PM
hurst2001
Nov 16, 2015 01:40 PM
2HHR Family
Mar 22, 2014 01:27 AM
