Floor shifter wont come out of Park 2009 HHR LT
Old May 9, 2021 | 01:46 PM
GreyHHR#2009's Avatar
My 2009 HHR FlexLT will not shift out of PARK.
Doors closed, Seatbelt on.
Engine running.
Push the button on selector you can hear a click coming from the dash.
Service Air bag light on.
Change oil light on.
Check engine light on.
I do not own a Tech II meter.
Old May 9, 2021 | 01:55 PM
Are you depressing the brake pedal?
Old May 9, 2021 | 02:08 PM
X2 ^^^^^
Old May 9, 2021 | 02:20 PM
Yes
Crawled under the dash and pushed the brake pedal , could not hear a click from the switch.
It has 3 wires. How can I check it before taking it out and changing the alignment ?
Old May 9, 2021 | 03:48 PM
Do your brake lights work? I would ask about cruise control, but it's stuck in park...
Old May 9, 2021 | 03:53 PM
Can you get up there and press the switch, see if you hear the click?
Old May 9, 2021 | 03:54 PM
09, I think it's a pedal position sensor, not the regular switch.
Old May 9, 2021 | 03:55 PM
Yes the Brake lights come on
Old May 9, 2021 | 03:58 PM
Its a rotating switch that has forks that go around a post on the pedal bar.
Old May 9, 2021 | 04:50 PM
Yes, that's the pedal position sensor.
