Floor shifter wont come out of Park 2009 HHR LT
Old May 15, 2021 | 02:23 PM
GreyHHR#2009's Avatar
Yes, that's the pedal position sensor.
I bought a new sensor . No change.
I start the car, push the button on gear selector(can hear a click near the steering column in the dash. Still can get out of PARK.
Would it matter that the battery has been disconnected for several months?
Old May 15, 2021 | 02:30 PM
It will matter if the battery is dead.
Old May 15, 2021 | 03:05 PM
Are we forgetting the extended warranty?
If the button is stuck or doesn't do anything:
On the right side of the shifter mechanism there is a tiny servo, try squirting some WD40 or your favorite on it.
If the button is loose:
There is a Dorman repair kit that replaces the shaft from the button down to the switch.
https://www.chevyhhr.net/forums/general-hhr-4/2010-hhr-gear-shift-button-stuck-park-60590/
https://www.chevyhhr.net/forums/prob...ck-park-60857/
https://static.nhtsa.gov/odi/tsbs/2014/SB-10081081-0335.pdf
Old May 15, 2021 | 03:22 PM
the battery was new when the tender was placed on it.
The car starts and runs fine.
Old May 15, 2021 | 03:41 PM
Try this solution
or this method
here are some other threads about the problem
https://www.google.ca/search?q=hhr+s...iw=414&bih=710
Old May 15, 2021 | 03:44 PM
Somehow post #13 is getting ignored. Probably my fault editing it.
Old May 15, 2021 | 03:45 PM
It shows up now, Donbrew.
Old May 15, 2021 | 03:50 PM
I don't recommend the top youtube fix; it is dangerous the ****er can be moved without any inter lock.
New shifter were under $100.last I looked.
Old May 15, 2021 | 04:55 PM
Watched both videos. Thank you
Push the brake pedal - no sound
Pull in switch on gear selector- it moves the actuator and there is a click in the column.
Cleaned the solenoid.. Lubed it.. Pushed brake pedal with key on , solenoid dose not move in gear selector.
Going to immobilize the solenoid lever inside the gear selector.
Old May 15, 2021 | 05:47 PM
Send hellshotrod a PM , he should have a good shifter assembly
