fog lamps
Old Jun 15, 2018 | 09:34 AM
mercury2005's Avatar
fog lamps
My 2009 LS Panel does not have the wiring for the fogs where the fogs install.
However the wiring is there behind the radio panel.
I installed the correct panel and fog switch along with new fogs.
I was thinking I could go the the junkyard and remove the factory harness which I assume would go from the fuse block area to the fogs and install the harness on my truck.
Has anyone done this?
Old Jun 15, 2018 | 11:08 AM
No, I haven’t but the BCM is involved somewhere.
Old Jun 15, 2018 | 11:29 AM
Silverfox's Avatar
Just a thought.....
Might it be a possible to just wire them direct to the battery with an inline fuse if you cannot get all the factory stuff ? I would look at the Satellite battery posts under the hood as a possible hook up location.
Silverfox
Old Jun 15, 2018 | 12:58 PM
If you are doing a "factory" install you will need to have the BCM programmed. And wire it to a relay & fuse in the under hood fuse box.
You can wire it up with relays to work legally and safely, see the how-to section, there is at least one method.
https://www.chevyhhr.net/forums/how-...al-library-21/
Old Jun 15, 2018 | 06:37 PM
https://www.chevyhhr.net/forums/how-...tory-fogs-637/
This guy had a good how to.
Old Jun 16, 2018 | 02:43 PM
Ron S's Avatar
Originally Posted by Silverfox
Just a thought.....
Silverfox
Ihave used a different method due to the current draw on some driving lights. I would run a fused lead from the battery to a relay, it has been a long time but as I remember I used a Chrysler starter relay, and from the relay to the lights. My interior switch would just activate the relay and is just a very low current into the dash.
Old Jun 16, 2018 | 02:45 PM
Would the fog lights turn off when the driver switches to high beam?
Old Jun 16, 2018 | 04:32 PM
Somewhere on this site is a thread that has detailed wiring to make the fogs work safely and legally (off when hi beams are on). Basically a relay opens when hi beams go on so no energizer to the relay that turns the fogs on. Thus saving the BCM programming charge.
Old Jun 16, 2018 | 06:22 PM
Silverfox's Avatar
Originally Posted by Ron S
I have used a different method due to the current draw on some driving lights. I would run a fused lead from the battery to a relay, it has been a long time but as I remember I used a Chrysler starter relay, and from the relay to the lights. My interior switch would just activate the relay and is just a very low current into the dash.
Wiring directly from the battery with an in line fuse and a separate off/on Toggle or Rocker switch would leave the headlights and running lights as is.
Low and High beam should not be affected.
Get a Switch with a visible ON indicator so you won't forget to shut them off.
Considerate it as an Accessary.
I like to keep things Simple unless it's harder the then doing it the Correct Way .....
Silverfox
Old Jun 16, 2018 | 08:48 PM
Ron S's Avatar
silverfox thanks for reminding me I forgot the switch power source, I tapped in to the wire for the low beam. It has been 35 years since I installed one of these. Old age must be catching up with me.
