Fog light differences
Old Mar 8, 2017 | 05:19 PM
Here is one for a 2007:
21992589 | eBay
All of the switches just snap in.
Does your car already have the harnesses? The switch seems to have changed in 2008, I don't know about the wiring.
Old Mar 8, 2017 | 05:21 PM
Fog Light Switch ACDelco GM Original Equipment 15933137 fits 08-11 Chevrolet HHR | eBay
Is for 08 and up, this Rockauto link shows the correct 2007 switch
More Information for STANDARD MOTOR PRODUCTS FLA1059
GM shows it's obsolete
http://www.gmpartsdirect.com/oe-gm/21992589
Old Mar 8, 2017 | 05:30 PM
Yes, they did change I don't know the difference. Looks to be a different shape, I don't see a difference electronically.
Chevrolet GM OEM 06-07 HHR-Fog Lamp Switch 21992589 | eBay
Here is the wiring for 2007
Old Mar 8, 2017 | 05:38 PM
If the only difference is the shape, it might be cheaper to get a new waterfall from a 2008+.
Old Mar 8, 2017 | 06:20 PM
Liquidh8's Avatar
Thanks guys. I did get the 07 schematic from Mitchell pro on demand, I was going to compare the 08 but you already confirmed electrically they are the same. I had thought about getting a newer waterfall and just going that route.
I searched eBay too and didn't find a switch, but you did, man you guys are good.
Old May 27, 2017 | 12:28 PM
aradmahogany's Avatar
anyone have an idea on how to remove the blank switch for fog lights on an 06? Does it pry off? Accessible from up top by removing the storage bin? I have an idea of using that space to make a mounting spot for my phone but I need to get that blank out of the way first!
Old May 27, 2017 | 12:36 PM
I thought that you just pull the waterfall off and access from the back?
Old May 27, 2017 | 01:13 PM
Probably. I just didn't want to go digging around if I didn't have to. I also figured you might be able to be sneaky and go in from up top.
Old May 27, 2017 | 02:30 PM
Nope you need to pull the waterfall
Old May 31, 2017 | 10:07 AM
Liquidh8's Avatar
Yes, pull the waterfall and access from the back.
nacademus
Aug 28, 2011 08:35 AM
sleeper
2.4L Performance Tech
7
Aug 28, 2009 11:17 AM
GWDavis28
Mar 21, 2009 09:43 AM
mchuntley
Jun 10, 2008 10:52 PM
RUDEINC
Aug 21, 2006 01:20 AM
