Fuel Gage drama
Old Jun 12, 2022 | 01:18 PM
Bonez's Avatar
It was 100 miles...
correct and it has me baffled as well. I know the fuel tanks ( especially on newer cars, the fuel pump and sender sits into a "baffle" so the sender really doesnt move much since the fuel is regulated by precise openings so it takes a bit of time for the fuel to rise/lower which I assume one refered to as buffering, its just a controled flow. I am going to take a peek under in a bit here and see if anything is loose or whatever. I filled up this morning and it only took 10 gallons so it was very conservative on gas as I filled up before leaving... amazing !
Now lets see if I can find anything under the car.
Old Jun 12, 2022 | 01:34 PM
Originally Posted by donbrew
It is relevant that the mileage calculation was correct. That means that the BCM was getting data from the tank.
Perhaps something loose on the instrument panel, or between the IP and BCM.
Old Jun 12, 2022 | 01:36 PM
Bonez's Avatar
Nothing loose or damaged, actually everything looks really good, like this car was kept in a garage. Underside is immaculant for the most part, very clean.
Old Jun 12, 2022 | 03:05 PM
https://www.rockauto.com/en/catalog/...assembly,10147
If you look at the photos for the fuel pump, the float for the fuel gauge sending unit is outside of the baffle to prevent the fuel pump from cavitation from any fuel slosh in the tank.
Yes it looks very clean under there but how’s about the connector for the fuel pump?
Old Jun 12, 2022 | 03:40 PM
Bonez's Avatar
wasnt able to reach it on the gravel, going to try and set a time with my son n law to throw it up on the rack and go over everything on the underside. I am hoping to get a car lift installed in my garage, debating which one to get.
Old Jun 12, 2022 | 04:32 PM
  #26
Not the rack!
Ronnie
Maintenance and Upkeep
29
Mar 4, 2022 12:35 PM
carrzkiss
13
Mar 15, 2021 04:33 PM
Oldblue
Mar 14, 2018 09:41 AM
Lawagz
Mar 12, 2014 03:49 PM
firemangeorge
Fuel Economy - Hypermiling
Apr 26, 2012 02:39 PM
