Getting closer on buying HHR but...
Old Nov 17, 2007 | 06:38 AM
Originally Posted by SIRESMERPH
i think one of the major changes for the 08 other than lil options here and there is just the body styling. smooth bumpers for 08.
Nope, here is hitec4you's 2008 HHR. No smooth bumpers.
The SS has smooth bumpers however.
Old Nov 17, 2007 | 07:10 AM
Originally Posted by MWG2
I guess there is no difference between a 2007 2LT and a 2008 2LT
Only difference between the 07 and 08 2LTs is that now the running boards come with the 08 2LT.
Old Nov 17, 2007 | 08:16 AM
hhrcrafty's Avatar
The rotors on that car probably had a bit of light surface rust from sitting out on the lot and the pads would have re-seated themselves after a day or so. No biggie.
On extended warranties--after selling cars and appliances, I will always buy one. Even on the so-called "reliable" brands, they're still mechanical pieces and something will ALWAYS break. Sure, you could put your money into an ING account and start drawing interest on it, but figuring taxes and withdrawal penalties when your $1500 BCM takes a dump in the middle of nowhere, the GMPP looks like a pretty good plan.
Old Nov 17, 2007 | 09:10 AM
Lone Ranger's Avatar
Mine did the same thing on brakes. Note the build date vs. buy date in my signature. It is "lot rot" as mentioned above. Normally the dealer should take care of the brake rotor grind as part of pre-delivery procedure after sale.
What happens is as the car sits unmoved the rotors get some rust everywhere except right under where the pad contacts the rotor. This makes a smooth spot in a sea of chaff on the rotor surface and thus the pulsation when brakes are applied. They have to remove VERY little rotor surface to make it uniform again, so it doesn't effect rotor life noticably.
Old Nov 17, 2007 | 02:28 PM
MWG2's Avatar
All your advice Lone Ranger is excellent. THANK YOU very much!!
doty21
Mods - Exterior
Jun 30, 2011 10:46 AM
P-38 Sam
Jul 16, 2010 01:56 PM
mchuntley
Mar 11, 2008 08:10 PM
MWG2
Dec 3, 2007 08:21 PM
billbeau
Jun 16, 2007 11:30 PM
