was gifted a HHR
Old Nov 20, 2019 | 06:53 PM
iGoya's Avatar
Hi iGoya, to the forums!
You need new speakers, pretty common problem here.
Go to your nearest auto parts store and get the codes pulled. Post them up here, just the codes, not descriptions, as they can be misleading. Let's see if we can point you in the right direction with regard to the sputtering.
Welcome.
If you do get the codes read and post them here, please post them in the correct format. It should be like P0001, P0002. One letter and 4 digits for each code.
Originally Posted by donbrew
We are AssUmeing that you read the Owner Manual and know how to adjust the front to rear fade?
The fuel pickup is on the bottom of said "canister". More likely one of the EVAP vents is blocked, but the code would tell.
Old Nov 20, 2019 | 07:25 PM
Those codes pertain to the VVT solenoids. Here's the how-to(pretty easy job).
https://www.chevyhhr.net/forums/how-...13-14-a-28779/
Old Nov 21, 2019 | 01:55 PM
PulpFriction's Avatar
Re: P0010, while it could be a wiring problem or something else, after a quick look-over of the wires leading to it, simply replacing that actuator is a pretty good low-cost bet. There are two very close to one another; “A” intake, the one in the front.
I assume you have the base radio. I had two HHR’s with that. They both had speaker problems. I suspect the feeble radio ensures the demise of the low-grade speakers. If you want the budget fix and keep the original radio, you could just replace the front speakers with the cheapest aftermarkets you can find. They’ll be better that stock. Just set the fade all the way forward - more Watts for the front. I understand the tiny speakers in the pillars never fail. Mine haven’t.
Good luck! Looking forward to hearing about your results.
Old Nov 21, 2019 | 02:33 PM
iGoya's Avatar
Re: P0010, while it could be a wiring problem or something else, after a quick look-over of the wires leading to it, simply replacing that actuator is a pretty good low-cost bet. There two very close to one another; “A” intake, the one in the front.
I'm planning on getting to that this weekend ill keep you guys posted on everything
Old Nov 21, 2019 | 02:46 PM
Cat Man HHR's Avatar
We are AssUmeing
I love this word.
Never do what it implies.
Old Nov 23, 2019 | 09:14 AM
Casa Del Gatos's Avatar
I just replaced both of mine.
Here is the deal on Amazon.
CMP Actuator Solenoids
SirCorgi
Jun 24, 2024 07:31 AM
Dhorning23
2.4L Performance Tech
Feb 4, 2017 09:56 PM
Lynell Sharp Lambert
Jan 5, 2017 09:51 AM
Imonlyusingthisonce
Jan 17, 2016 09:48 AM
yrrah
Nov 15, 2013 08:41 AM
