Guage cluster question
Old Jan 7, 2014 | 05:18 PM
Allen S's Avatar
I understand that when you change your guage cluster, you must have it reprogramed. What about if you are simply reinstalling the origional? Does disconnecting the plug from the back change anything? I don't think it should, but i'd like input from someone who has done it. Thanks.
Old Jan 7, 2014 | 05:41 PM
I have removed mine to clean the screen and dials ( PO was a heavy smoker) I disconnected the battery neg terminal first then removed , cleaned and replaced the cluster, reconnected the battery. No problems at all.
Old Jan 7, 2014 | 07:25 PM
Lucky's Avatar
X2. Just disconnect the battery before you remove the cluster and you will be fine.
Wolfblitz
Aug 11, 2012 03:09 PM
Sheverlay
Oct 12, 2009 03:11 PM
