Had a BIG problem this morning....
HHRs(as well as almost all current production GM) starters are activated like this.
key in and turn to acc: +12 volts applied to acc curcuits
key to ignition: +12 volts is applied to acc and ign.
key to start: +12 volts is sent to starter as -12volts is sent to ign and acc.
the process of starting BEGINS when the key is moved from acc to ign to start and it ENDS when the vehicle starts...not when you turn back the key like older cars.
The car simply was carrying out the last comand you gave it when it was able to do so. Since you also tried to remote start, the passkey+ system was also bypassed for one startup cycle.
The airbag light was brought about since second ign and second acc were not inergized appropriately and in the correct sequence.
In short... get the car serviced.
As for a vehicle that starts with NO key in the ignition and the remote start not pushed I am not happy with that. What if I would have opened the hood to check anything? Could have been a bad deal!!
There are 8 conditions that won't allow the remote start to work, one being if the hood is open, so you needed worry about that.
With it that friggin' cold, my guess is that you were lucky it started at all, and when it did, idling does nothing to recharge the battery, my guess is that the battery voltage was barely adequate and funny things start happenning with low voltage in that car. I had a dud battery and thought the DIC was royally screwed up but everything normalized with proper voltage.
No starter grind?
I once watched a woman grind her starter over and over about 4 or 5 times, could not believe what I was seeing. The motor was so quiet she didn't hear it I guess, clash after clash after clash.... Lady! IT"S RUNNING !!!
Kind of knew that something was a little different in the way the HHR starts. Good explanation, thanks.
Couple of dumb questions come to mind.
So in theory you could hold the key in the start position forever once it started without damaging anything?
If ign is not getting voltage (-12) in the start position how does it have ign current to run with, some kind of starter / ign bypass?
Thanks.
Thanks.
Since that day everything has been fine, even on a colder day. The HHR starts great and I love that.. No being stuck at home with a dead vehicle
Consider this for what it's worth. (My car is so old it has not one cup holder.)
In cold weather these delays occur. No problem in warm weather or when the car interior is good and warm.
1. Turn on turn signals. One or two minute delay before they decide to blink.
2. Turn on winshield wipers. One to two minutes until they decide to wipe.
3. Turn off wipers. Stay put for up to a minute or two then decide to return to park position.
4. Tachometer reads a factor times the true speed. Continues to malfunction even after the car is warm. Resets by restarting the car.
I think, 1, 2 and 3 are caused by dirty switch contacts where the dirt is stiff when cold. (So perhaps the remote did its job of switching the starter relay, but like my electrical when cold, the actual contact was made some time later.)
Oh Sh$% moment. Nothing happened
No starter grind.
