Have a cooling issue….
Old Feb 5, 2025 | 07:00 AM
Just cool clear water!
Old Feb 5, 2025 | 09:00 AM
PulpFriction's Avatar
^^^This.^^^
And then, don’t use the premix, in case there’s still some water in there. Calculate how much CONCENTRATE the system needs, mix 1/2 of that with water 2:1 and dump that in, then top off with 1:1, fill the recovery tank with 1:1, and burp a few times, adding 1:1 as needed. That way you will have a perfect 1:1 in the system. (But in my climate I like it a little richer, just in case of a crazy cold night.)
Old Feb 5, 2025 | 09:14 AM
The Prestone 50/50 premix Dexcool has a rating of -37 degrees F , it works great up here!
Old Feb 5, 2025 | 09:28 AM
Yes it does. But the record low for Ohio I think is coincidently -37, so betcha it’s a little less in yer neighborhood. And GM does recommend 60:40 for certain unlivably frigid climes. (Autocorrect changed unlivable to unlovable, lol.)
Old Feb 5, 2025 | 11:31 AM
I’m just pointing out the specifics of the solution
Old Feb 7, 2025 | 10:02 AM
  #26
Gearhead1's Avatar
Changing Thermostat…
If I drain the radiator will that lower the coolant level enough or do I need to remove waterpump drain plug? ..,trying to save my coolant,….not very old
Old Feb 7, 2025 | 10:19 AM
  #27
Lower the coolant level enough to do what? You've talked about replacing the pump, the filler neck, the thermostat, and flushing the coolant.
Old Feb 7, 2025 | 10:24 AM
  #28
Gearhead1's Avatar
changing thermostat.
Old Feb 7, 2025 | 10:28 AM
  #29
No need to drain. You will only lose a few ounces removing the t-stat.
Old Feb 7, 2025 | 05:51 PM
  #30
Gearhead1's Avatar
Well….got the new AC thermostat in…figure mostly burped…check again in morning….so far seems to have made a difference..even idles better which is confusing to me…lol Changed oil and filter. Know more when get on interstate at speed and mountains.
Got new AC plugs on the way.
