Help
Old May 7, 2006 | 12:23 PM
Help
My HHR doesn't want to release the key from the ignition. Any input (even the obvious) is needed! I've a 2LT w/ auto.
Events leading up to this occurance....
Just got home.... put her in park....turned the key back. Just like every time I get home, but this time the key is stuck!
Thanks in advance for any/all info!:twothumbs
Old May 7, 2006 | 12:28 PM
captain howdy's Avatar
I had that happen once. I turned the steering wheel until it locked and the key came out just like normal. I also have the 2.4 with auto.
Old May 7, 2006 | 12:31 PM
On my way to try that. Thought I had done this, but maybe I didn't turn the wheel far enough. BRB
Old May 7, 2006 | 12:35 PM
Just returned, with no luck! The key won't leave the accessory possision, so the wheel will not lock.
Old May 7, 2006 | 12:37 PM
That's odd. Sorry, I can't think of anything else right now.
Old May 7, 2006 | 12:40 PM
Thanks for the try.
Old May 7, 2006 | 12:45 PM
Skatetheglobe's Avatar
try stepping on the brake and putting it in gear then put it back in park.
Old May 7, 2006 | 12:48 PM
Already tried that, as well as taking her aroung the block going through all the gears. Both results came with no luck.
Old May 7, 2006 | 12:53 PM
PhxHHR's Avatar
Hit your On-Star button and see what they recommend - still under warranty, right?
Old May 7, 2006 | 12:54 PM
Not everyone has OnStar. I know I didn't want it.
