Help
Old 12-28-2020, 10:59 AM
Don Z Jeep's Avatar
2008 hhr 2.2 manual...car dies overnight (new battery) flashers or blinkers never make a sound stock alarm works only after you turn of the ignition for a short time tire service light is always on an the tires read blank...
Tire Pressure Monitoring System where is the pcm located helpppppp!!!!
Don Z Jeep is offline
Old 12-28-2020, 11:06 AM
Sounds like a dead battery have it load tested, I merged your 3 threads
Oldblue is offline
Old 12-28-2020, 01:11 PM
WoodysMobile's Avatar
Same year and transmission
I'd have battery load tested first and foremost.
My TPS light is always on too. I have new sensors to install but can't get access to system with keyless remote (another story)
My HHR has more electrical gremlins than most any vehicle I've ever owned.
Battery test results?__________________________...
WoodysMobile is offline
Old 12-28-2020, 02:20 PM
Someone remember the TSB number for the 2008's ? The one regarding the computer loosing memory after a dead battery.
firemangeorge is offline
Old 12-28-2020, 03:43 PM
Might we assume this car is new to you?
Does it have the Original radio? The chimes are played by the radio.
Yes, 2008 models do need updated firmware for the RCDLR if the battery has gone dead. Replacing it will not fix it unless it gets the new firmware installed. To answer the question the RCDLR (the receiver for the fob and TPMS) is located under that bump in the headliner near the mirror.
donbrew is offline
Old 12-28-2020, 03:45 PM
Don Z Jeep's Avatar
Battery test results?________battery is new __________________...
an I returned it an got another
Old 12-28-2020, 03:58 PM
To clarify, you returned the new battery and got another new one?
Oldblue is offline
Old 12-28-2020, 04:12 PM
Don Z Jeep's Avatar
Reply
yes I got a new one it dies I drive it it works all day then I park it at night in the morning it doesn't start
Old 12-28-2020, 05:06 PM
Do you leave anything plugged into the cig lighter?
When did this start?
Please just tell us something in complete sentences. I really hate playing 20 questions.
donbrew is offline
Old 12-28-2020, 06:41 PM
Yes, something is discharging the new battery, anything from a shorted wire, improperly installed aftermarket radio or amp, phone charger plugged into the power outlet, dome light left on....
Oldblue is offline
Quick Reply: Help
