HHR 2.4 LT after 5000 km, good
Old Apr 5, 2018 | 06:52 AM
  #31
M3ndoR's Avatar
Originally Posted by Cat Man HHR
Yes
Thank You, lets get to work
Old Apr 5, 2018 | 08:18 AM
  #32
Originally Posted by M3ndoR
So im in deep woodps. Transmision pan covered in black drops, so engine oil on transmission pan ?
Check around the oil drain plug.
From 5,000 miles that looks reddish on the ground.
Old Apr 7, 2018 | 11:26 AM
  #33
M3ndoR's Avatar
For fob start ?
Upper or it is good ?
Old Apr 7, 2018 | 11:36 AM
  #34
You might disconnect and clean, apply some dielectric.
Old Apr 8, 2018 | 12:10 AM
  #35
M3ndoR's Avatar
No need its clean
so ive unpluged the battery for 30 min. And after ive tryed to start from fob, the car started, was workin gor 5 sec and then the engine stoped. Any ideas ?
Another problem is with my transm. pan, its covered in engine oli, the oil drain is dry. I cant find the leak.. Transmission pan
Trans pan #2
​​​​and the last thing, yesterday ive started the engine and the rpm go to 1000 rpm, then afted 10 sec. They go down to 500-700 and stay there waving at this level. Its very anoing when i stop at the traffic lights cause car works like a tractor or diesel engine that is used off, what can be the problem? Sparks ? Engine caches unwanted air ?
Old Apr 8, 2018 | 08:23 AM
  #36
A dirty throttle body and or MAF sensor.
Old Apr 8, 2018 | 08:52 AM
  #37
It looks like the leak is the transmission pan gasket. It is missing at least one bolt.
Old Apr 8, 2018 | 10:22 AM
  #38
I suspect that the hood latch switch is broken.
You probably can bypass it by following the directions in https://www.chevyhhr.net/forums/how-...ion-ap3-28551/
Old Apr 10, 2018 | 03:19 AM
  #39
M3ndoR's Avatar
Greetings!
Lots of work was made.
1. Fixed the lamps bulbs
2. T/c problem - rather solved. Car signals t/c when im on lpg, after drivin around on gas t/c didnt show not once.
Problems to solve
- check engine
- leak under the engine, transmision pan is covered in engine oil, i think that the gasket of crankshaft is lose
- rear spribgs need tobe chnged one is broken
T/C - this is strange. What T/C has in common with fuel i use, and what is the connection betwen transsmision shift and the fuel i use ? On lpg the shifts are not so fluent as on gas.
Old Apr 10, 2018 | 08:03 AM
  #40
T/C turns off when there is a DTC fault. I thought that was explained long ago.
It is not the fuel, it is the P0172/P0171 or whatever you have.
That looks more like trans fluid to me. Have you changed it? The gaskets are a bit tricky to put back on.
