HHR Explodes
Old Mar 24, 2019 | 08:53 PM
Originally Posted by OldSwede
I believe that might be termed a "fuel-air explosion"...........
I believe you're right...
Old Mar 25, 2019 | 10:13 AM
J W Davis's Avatar
Wonder IF the leaking fuel lines or vapor return line might have something to do with it?
Old Mar 25, 2019 | 11:20 AM
Did you read the linked article ?
Doubtful since it said body spray and a lit cigarette.
Old Mar 26, 2019 | 08:40 AM
J W Davis's Avatar
Yes, I read the article about the body spray. Just find it hard to believe that this was the only issue here.
Old Mar 27, 2019 | 10:16 PM
Hard to believe the guy survived...
Old Mar 28, 2019 | 09:17 AM
solman98's Avatar
Vapor explosions end about as fast as they start. I'm sure they guys ears were ringing for a while after.
Old Mar 28, 2019 | 12:04 PM
He may have lost some hair...
Old Mar 28, 2019 | 01:06 PM
Who needs eyebrows??
Old Mar 28, 2019 | 01:30 PM
Cat Man HHR's Avatar
With the concussion/explosion that happened, I bet it did.
Old Mar 28, 2019 | 07:09 PM
Snoopy's Avatar
I can testify that this is easy to do.
I had a significantly stupid situation similar to this....
I'll shorten the story considerably.........I have a large business size paper shredder. It came time to empty the waste and I removed the container and bag to take out side. At the same time I noticed the shredding mechanism needed cleaning as well, so it was unplugged and taken out as well. Paper pieces were carefully removed from the shredder head, it's a "confetti" type so multiple sharp cutters. Noticing a lot of paper "fuzz" I decided to blow it out with compressed air. Being lazy, it's a big large shredder, I elected not to utilize my garage compressor. Instead I used canned air.....the type that's used on computers and such. Did a great job and took everything back into the house, assembled, dry lubed and plugged it in. Of course it would need testing. Went to shred a piece of scrap paper and it went BOOM. Apparently THE CANNED AIR PROPELLENT WAS COMBUSTABLE. Luckily there was about 15-20 minutes in between the air spraying and the start up. No injury, BUT I learned a lesson. I ARE DUMB.
You may laugh now and call me names!!
