HHR Interior
Old May 18, 2006 | 11:53 AM
  #71
Harpozep's Avatar
Just adding more info to the thread
That's the same dask kit I've seen a million times. Not the one yeshua63043 just posted the link to and that I asked JoeR for pics of.
Yup, I'm with you and would like to see that new kit as well.
Still, I posted the link to be helpuful in a different way. That is, to show the effects of different color dash kit stuff used in a tan interior ( except for the HHR photo, I don't know what the other car is). The eight examples in the ebay ad are useful in this manner. They help me realise I'd like a darker kit rather than a lighter one.
I figured this is a recent post, so having more kit info in the thread should not be a bad thing?
Sorry to confuse you, though it seems the post was helpful to zwede
Old May 21, 2006 | 01:31 PM
  #72
1bad, how did you do the door trim?
Did it come off and if it did how? If not how did you paint it?
I think because of cost and matching the exterior paint I've decided to paint.
Old May 21, 2006 | 02:29 PM
  #73
TNHHR1's Avatar
Originally Posted by JoeR
I've had this kit in mine for some time now, but only used some of the pieces. The quality is great and some things distinguish this from others. This was the only one I found that had a piece for the window switch panel. I also liked the strips for the doors.
The only negative is the two pieces for the steering wheel switches. Too much curvature and they want to pull loose at the bottom. I already redid the adhesive and hoping they hold.
Joe...
Dashkits does not have pics of an HHR...IT IS UP TO YOU!
PICS PLEEEEEZE!!!!
Old May 22, 2006 | 05:17 AM
  #74
1 BAD HHR's Avatar
I actually just taped off the stripe (making sure the tape was in the groove) and used plenty of newspaper to shield the interior of the car. But I would take the door panels off if I had to do it again. The stripe is not removable, so everything was done in place.
Old May 22, 2006 | 06:54 AM
  #75
Skatetheglobe's Avatar
Originally Posted by slamed87lincoln
.im right at 6ft and weigh 360..so im no small man...in fact im rather fat ....
That would explain the gargantuan sig...
Old May 22, 2006 | 09:42 AM
  #76
Thumbs up
Thanks for the help!
Old May 22, 2006 | 06:07 PM
  #77
One more question......what did you do to prep the surfaces for painting?
OK, I lied two questions
Did you use a clear coat of any kind?
Old May 22, 2006 | 07:18 PM
  #78
SindyDix's Avatar
Gosh, decissions decissions.... both kits have pieces that the other doesent. On their sites, www.edashkit.com and www.exoticwoodtrim.com
I wonder if either site would sell "missing" components that the other kit doesen't offer. They both seem to offer the same types of materials to select from.
Old May 29, 2006 | 06:42 AM
  #79
1 BAD HHR's Avatar
Sorry about the delay posting this....
I used a 1000 grit sandpaper and wet sanded the areas to be painted. Some guys will tell you not to sand plastic. I've been doing this for years....It's okay, just use no less than 1000 grit.
Also, use a 1200 grit betweeen coats. and finish with a clear coat.
Old May 29, 2006 | 12:29 PM
  #80
TNHHR1's Avatar
I think I've called them all....nobody wants to sell individual pieces. If they do not show you as a customer...no sale...
capp002
Mods - Interior
Aug 23, 2011 07:59 PM
TY&HHR
Oct 27, 2008 08:58 AM
thunderstruck88
Jun 24, 2008 12:13 AM
Donadio
Nov 28, 2007 03:51 AM
