Hhr power window problem
Old Nov 22, 2023 | 02:03 PM
Callen's Avatar
I cleaned original switch first didnt help.. i just bought the car and im trying to get it certified but i cant figure out thewindow issue.. i dont think ground. Is bad i can jump the 12v green and black to the motor and it will work but when i attach the switch it only passes 6v i dont know if theres anything done to it but the speakers dont work either only the front pilar speakers maybe the person before me had a different stereo in it because it looks like its missing a sub woofer in the back someone had installed at one point. The cars only got 90 000 km Thanks for the suggestions guys
Old Nov 22, 2023 | 03:09 PM
Callen's Avatar
Hey guys i just checked the 30 amp fuse for the windows under center console and im not getting power when the cars on or off what would cause this and could that be my problem? The yellow and black wire from rap seem to be getting a good 12v it will run the motor when i jump the power over but across the black and green there is 13v when the car is running but drops to 0 when i connect motor where does that fuse get power from?
Old Nov 22, 2023 | 03:13 PM
Callen's Avatar
Actually never mind im getting power to the 30 amp fuse when the cars on and off what i was using for ground wasn’t sufficient
Old Nov 22, 2023 | 08:11 PM
Callen's Avatar
Figured it out guys it was the green wire junction at j323 under front driver seat im having. Beer im so happy lol
Old Nov 23, 2023 | 06:57 AM
Ah! It solution a bad ground wire! I’m glad you found the issue!
Old Nov 24, 2023 | 08:56 AM
  #26
PulpFriction's Avatar
The speaker problem is probably unrelated. If you have the basic speakers, they're probably blown. Best to just replace all 4 door speakers. Even inexpensive ones will be an upgrade from the OEM junk.
Old Nov 24, 2023 | 01:24 PM
  #27
J323 is the 12v supply to each door, not ground. Somebody must have mucked with the wires for some after market shenanigans; pretty difficult to disconnect 2 wires in a 5 wire splice.
hocuspocusblade
Apr 15, 2023 10:54 AM
Tyler Harvey
Apr 8, 2017 04:04 AM
jwjones
Nov 19, 2013 04:16 PM
aloppen
Nov 13, 2011 03:01 PM
oldspowered
Nov 17, 2010 08:24 PM
