High mileage club 100,000 plus
Old Oct 5, 2025 | 01:10 PM
  #331
TechDog's Avatar
Just hit 230,000 miles.
I've heard the engines are designed to to go 250,000.
Should I start to worry?
Old Oct 5, 2025 | 05:17 PM
  #332
pkelley57's Avatar
2007 w/276,847 miles
2.4L 5-speed manual, 2007, 276,847 miles, and still running strong.
Old Oct 6, 2025 | 01:16 PM
  #333
Lonwane's Avatar
TechDog,
Worry will depend on your maintenance schedule or lack of one.
SISU, my 2006 2LT, has 236k miles and I'm looking for another 200k.
So far I have replaced the timing & balance shaft chains, water pump and alternator.
Oil changes every 2500 miles.
So, it all depends
Old Oct 7, 2025 | 05:33 PM
  #334
PulpFriction's Avatar
This thread started in 2011. Both of my HHR's are now just over 100K, but now, 14 years later, that's LOW mileage.
Old Oct 16, 2025 | 11:07 PM
  #335
Interceptor's Avatar
My recently purchased 2008 has 272,000. Runs good
Old Oct 17, 2025 | 09:20 AM
  #336
TechDog's Avatar
I had the chains and water pump replaced a couple of years ago.
This engine runs like a dream. As soon as I started it at the test drive, it was obvious, I had to buy it.
I wrecked my previous HHR panel, I had bought used, and it's engine was noisy and had less power.
Thanks!
Old Oct 17, 2025 | 12:25 PM
  #337
Glad it’s running smoothly
Old Oct 17, 2025 | 12:46 PM
  #338
TechDog's Avatar
Hopefully it will last as long.
Old Oct 17, 2025 | 06:53 PM
  #339
Gearhead1's Avatar
2011, 2.2…..277,xxx miles
Put almost 150000 driven miles on this car
Old Nov 12, 2025 | 04:43 PM
  #340
Low compression
Well the HHR was tested today for miss on #2 cylinder.
low compression, 50 lbs. Not going to repair since it has 273,000. Just gonna drive to the ground. Weird. It only skips at idle, runs fine going down the road. Thought for sure it would be a injector or something easy to repair when I purchased
