High mileage club 100,000 plus
Old Jul 8, 2014 | 03:54 PM
  #31
geesh's Avatar
almost 400,000
2009 hhr Ls 2.2. Currently at 399,072 miles... Aka 642,257 kilometers! Replaced engine at 395,000 kilometers and trans at 2xx,000 kilometers (can't remember exactly when off the top of my head). Hoping to get the car to over a million kilometers before she gets retired.
Old Jul 9, 2014 | 07:04 PM
  #32
ronp's Avatar
09 still running all original 265000
Old Jul 9, 2014 | 09:35 PM
  #33
sdavis1465's Avatar
2009 almost 240,000 here and my ignition locked into the run position. Waiting on parts for the recall. First real issue I had with it.
Old Jul 14, 2014 | 09:06 AM
  #34
prog2112's Avatar
2007 massive miles
I'm new to this site and was looking for the I'm new thread, then saw this. So,here is my first sub to you all.
My 07 that I purchased in 2010 had 91286 miles and a Left hub going out.
The dealer I bought it from ended up warrentying that. Why they would not fix before putting it on the lot is another story.
Drum roll, please.
Today, July 14, 2014..............Mileage is 555498! After work, same date: 555732::
So, as you can expect, I've had plenty of problems with it because I drive the wheels off of it.
A lot of the problems that I have seen here, actually all ot them, I've been through, with the most perplexing issue being the front end. Now, I have no idea what brand of part(s) was used to fix, but several have been warrentied and as of now everything is fine.
I'll find the thread that details what repairs have been done at some point, but there it is.
Pictures later.
Thanks to all the fine folks that post here.
Have a great day!
David Hanna
Old Jul 14, 2014 | 04:37 PM
  #35
udabney21's Avatar
I have a 06 with 276000 miles but recently threw a rod . Any suggestions or input on if I should rebuild the original engine, purchase an old used engine or chalk the car up for a loss? I have not had any major problems out of the car. Suggestions are definitely welcome.
Last edited by udabney21; Jul 14, 2014 at 09:35 PM. Reason: I originally put my remark in wrong place.
Old Jul 14, 2014 | 05:01 PM
  #36
prog2112's Avatar
udabney 21, tough luck on that rod!
I would compare cost of rebuild to cost of replacement.
I have no idea what the difference would be but there might be a salvaged lower mileage engine out there that would be as good if not better than some rebuilds. Depending on who you trust to rebuild current.
Good luck!
Regards
David Hanna
Old Jul 16, 2014 | 05:16 PM
  #37
vinnyac's Avatar
2006 HHR 2LT 2.4 I have 127,000 on it. At 72,000 fuel rail cleaned outside that, just normal wear and tear items. This HHR is Loaded down to the mud flaps, and runs like a BEAR !!!
Old Jul 18, 2014 | 01:21 PM
  #38
dphoffmann's Avatar
Hi All, I've been lurking here for a couple months now for repair advice. I have a stock Orange, 2007 HHR LT1 with 122K miles. 2.2L 5 speed Manual. The only item I've had to replace beyond regular wear items is the front shocks. The front end is starting to rattle over bigger bumps and potholes so I guess I will be investing in links soon. I have replaced the front rotors once and the pads three times. The rear drums and shoes have been replaced once. I have a minor leak on the tranny's outer cover. Still looking for the gasket to replace the leaking one when I service. Thanks for the help. I can't wait to get to 200K miles. That's when my daily driver becomes a toy for modification. I want to drop a supercharged 2.4L in for fun.
Old Jul 18, 2014 | 07:30 PM
  #39
spacer's Avatar
Based on some of these posts, my 130k or so miles has Herman barely broken in!
I did replace both front hubs about 10k ago, may have forgotten to mention that.
Old Jul 23, 2014 | 06:34 PM
  #40
spacer's Avatar
I spoke too soon. Just under 134k miles, my dealer tells me my transmission is on its way out. Nearly $4k for a factory reman tranny, including labor.
Curled up on the couch with a bottle of aspirin and Tums right now.
