Hit a bump so hard...
Old Feb 18, 2011 | 03:52 PM
stephofthedead's Avatar
On my way back from work, I hit a bump (pothole) so hard... the motor shut down! I pulled over and it started right up. I did not see any damage or leak but I will let it rest for a bit and check that out later.
Old Feb 18, 2011 | 03:56 PM
urbexHHR's Avatar
I think that's normal... When I drove my Lumina off a loading dock someone asked me if it shut off and was surprised it didn't. Can't remember why it does, but it's like some type of fuel cut off or something, probably so it shuts off in an accident.
Old Feb 18, 2011 | 04:10 PM
retrolled's Avatar
Damn, hope I don't hit anything like that but it's almost inevitable here in Indy. Not use to low profile, last vehicle had 295/75/16s and they were bad enough on some of these roads.
Old Feb 18, 2011 | 05:17 PM
Rod Run's Avatar
Huh? What? Story?
Old Feb 18, 2011 | 07:20 PM
Laco's Avatar
I believe all of the newer cars have some sort of an impact switch that kills the fuelpump. I'm guessing the impact of whatever you hit was sufficient to activate that fuelpump kill switch. On Ford products, it must be manually reset, I frankly don't know how the GM versions work.
Old Feb 18, 2011 | 08:09 PM
urbexHHR's Avatar
Originally Posted by Rod Run
Huh? What? Story?
No Dukes of Hazzard style flying or anything, but you can find the story in the first post...
https://www.chevyhhr.net/forums/show...=Lumina+meijer
Old Feb 18, 2011 | 08:24 PM
You just weren't going fast enough.....
Old Feb 18, 2011 | 09:43 PM
Fox Hat's Avatar
I used to drive a taurus wagon for work. My bro in law showed me just the right spot to slap the car to make the shut off work. Its a great security feature as long as you know how to reset it
aztrooper
Nov 4, 2014 02:38 PM
hobbytrucker1966
Mar 18, 2014 07:43 PM
roofer1976
Jun 18, 2009 09:24 PM
xzombiex66
10
Mar 14, 2008 12:59 AM
GDZHHR
Nov 9, 2007 08:36 PM
