How many miles did your struts last
Old Jul 23, 2015 | 07:40 AM
DwRed2LT's Avatar
Not sure where the sound is coming from.
Will update when the new left strut goes in as
to whether that was the problem or not.
123,300 and counting for both front and not a sound it seems
from the right front.~
Update in first post....
Old Oct 19, 2015 | 03:09 PM
dsipes61's Avatar
I just replaced struts, sway bar links, and lower control arms on my 2008 LT. 125,000 miles. The clunk I had was from the sway bar links. I put the Moog replacement links on and all the noise was gone. There was an issue with one ball joint so I did the control arms and struts at the same time. Rides and drives much better. thanks,
Old Oct 24, 2015 | 06:50 PM
Rod Run's Avatar
I changed out my original struts and springs with Pedders springs and factory SS struts, at around 20k and when I removed my originals, they both were leaking badly
Old Oct 24, 2015 | 08:43 PM
JCC's Avatar
JCC
I agree, Monroe quick struts on the front and KYB on the rear are what I when with. Monroe says to replace struts after 50,000 miles so I would get them local to be able to take advantage of the Life Time Warranty. Then replace them every 50,000 miles.
Parts like Monroe and Moog (and other US companies) are companies that do lots of research to improve over factory parts and do a great job at it. They stand behind what they make and have been around a long time. OEM parts are not always the best in many ways.
Old Mar 25, 2021 | 07:36 AM
desertrat's Avatar
Struts are a critical part that affects handling. The car may not track right or pull to one side if they are worn. I could not get my HHR to stop pulling to the left until I replaced the struts. The alignment shop did no good, and they never bothered to check the struts for wear. Struts are easy to replace, just remember there is a right and left side to them.
Old Mar 28, 2021 | 03:06 PM
PulpFriction's Avatar
With full knowledge that this is an old thread-
The FE3 shocks and struts are the only difference from the FE1 base “soft ride” suspension (as far as I can tell) and not only are they firmer, but they seem to last longer. The FE3 shocks on my 2008 were Sachs monotube. (My 2010 SS FE5 also has Sachs monotubes that look identical but care a different p/n, so probably different valving.)
I can confirm that Monroe “Quick-Strut” which include loaded springs for easy installation are satisfactory, but be sure to get the better black “OESpectrum” struts, not the blue “‘matics.” Just my opinion.
Also, KYB now seems to have “Strut-Plus” preloaded assemblies, which I wish were available when I last did struts.
All at Rock Auto, of course. Promo rebate on KYB right now.
Old Oct 2, 2021 | 08:36 PM
Tjethead's Avatar
2008 LS advice to soften ride
Own 2008 LS with 114,000 miles. Struts, rear springs & sway bar links need replacement.
Would prefer to soften ride. Your advice appreciated.
Old Oct 3, 2021 | 07:34 AM
Any of the quick strut items, Moog, Monroe, KYB , don’t forget the discount code from RockAuto!
Trex08
27
Feb 21, 2017 07:59 AM
navye9ret
22
Jun 19, 2014 11:22 AM
Kinison_fan
Maintenance and Upkeep
7
Jul 15, 2012 01:46 PM
mrbowtie
28
Dec 22, 2009 06:44 PM
HHorange
May 17, 2009 09:51 PM
