Installed OEM fogs on 2010 HHR LS-pics and questions.
Old Sep 24, 2011 | 11:40 PM
  #71
nacademus's Avatar
I went into the dealership and a gentleman at the parts dept. handed me a series of toolboxes FULL of various pins and connectors. He said to dig through and see which ones may work. They are a round pin- small, but not the smallest. They are ECM connectors. I took about 5 of each type ranging in size, really small "o" to "0" to "O".
I asked him how much they were and he let me leave with them-no charge.
I have no part number. They are small, round female pins.
At the PDC I just used as small audio female connector that I expanded slightly with a small flathead. It worked fine.
You have a GS550? Nice.
I have a 1969 T500 Titan MkIII
And a 2001 Ducati 996.
Old Sep 25, 2011 | 09:29 AM
  #72
GriffingR's Avatar
Nice toys!
I'll have to make nice with some of the part's guys and see what I can work out. I'm not too fond of them after what they want for keys/fobs. Then they wanted $40 each to program them...
Old Sep 26, 2011 | 12:28 PM
  #73
Sno White's Avatar
Originally Posted by GriffingR
Does anyone have a part number and/or source for the contacts that go in these connectors? I'm down to running the the wire from the BCM to the relay, and from the relay to the lights, but I don't know what these connector P/Ns are at the PDC?
According to my 2009 FSM the parts are called out as:
"Terminal/Tray: 15359541/4"
Notice these are actually two part numbers, I presume the first is what you need and the second is the connector body or tray.
Don't understand the reference to "PDC" in your post.
Old Sep 26, 2011 | 12:46 PM
  #74
nacademus's Avatar
PDC -Power Distribution Center
The fuse block under the hood-or any fused source of power.
Old Sep 28, 2011 | 07:34 AM
  #75
GriffingR's Avatar
Thanks for the P/N. I'll see if my local dealers have any in stock. As Nacademus stated, the PDC is the Power Distribution Center, AKA under hood fuse block.
Old Sep 29, 2011 | 10:51 PM
  #76
GriffingR's Avatar
This appears to be the P/N for the BCM end. I'm looking for the PDC end. I may have to go the route of Nacademus and adapt one of my MANY crimp-on connectors. They all seem to be either too wide across, or too thin through...
Old Dec 7, 2011 | 08:15 PM
  #77
06hhrls's Avatar
I just reprogramed my 06 LS bcm today at work. My LS already had all the wiring from the switch to the BCM and BCM to the relay. I had to run the rest. It works fine and the dash light works too.
Old Dec 7, 2011 | 08:43 PM
  #78
Cool 06 you made it look easy, Let there be light !!
CBurge33
Nov 30, 2011 05:52 AM
biglefthhr
Feb 16, 2010 01:19 PM
LTSport08
Mar 17, 2009 05:04 PM
dschoeck
Mar 27, 2007 09:01 PM
DARK AGE 53
13
Jun 21, 2006 08:53 PM
