Key FOB...hhr SS
Old Mar 9, 2013 | 05:41 AM
hickeybill's Avatar
Keyfob fix
I ordered a couple of button repair pads from Keylessfix.com. Cheap and they work great!
Old Mar 9, 2013 | 06:07 AM
arciolla's Avatar
keyless remote
Try www.keylessride.com
Old Mar 9, 2013 | 07:12 AM
radar910's Avatar
ref key fobs
go to keyfobs.com. they will send free for $39.95 sometimes with instructions
if your car supports owner setup,need to do both to have same operating
signal.
Old Mar 9, 2013 | 07:28 AM
db/sb's Avatar
signal.
The HHR does not support 'owner setup'. Not really sure what the rest of your post means........
Old Mar 9, 2013 | 08:17 AM
metal5818's Avatar
Yes , what an engineering marvel ? Ours went about 3 years before they started failing . A quick you tube search and learned of the battery holder brackets breaking loose from board . I soldered them back and one worked half way and the other still didn't work . So i bought two of the pads and installed them . Both are working fine except for the remote start . Local locksmith quoted me a price of $89 each to rebuild them . Funny thing to me , my 96' Geo Metro and 73' Dodge Van keys both work EVERY time ! And the batteries never go dead (in the keys) . BTW , our 2006 HHR has around 56,000 miles .
Old Mar 9, 2013 | 09:06 AM
db/sb's Avatar
Like I said in the other thread. Ours lasted the entire 7+ years we owner our HHR other than having to change the battery.
Old Mar 9, 2013 | 10:16 AM
Kevinmcl's Avatar
Originally Posted by metal5818
battery holder brackets breaking loose from board . I soldered them back.
Both of my 2009 keyfobs had to be soldered. Would work intermittently. I would tap it on my finger and it would work.
Ebay is a good place to get replacements, for as little as $15.00. I got one for a S10 Blazer that came with program instructions. They are very simple and might work for ours.
Transmitter Programming
1 With the driver door closed, hold down the power unlock button on the door panel.
2 Turn the ignition switch to the ON position.
3 Turn the ignition switch to the OFF position.
4 Turn the ignition switch to the ON position.
5 Turn the ignition switch to the OFF position.
6 Release the power unlock button on the door panel. The remote control door lock receiver will respond in the following manner in order to indicate that the receiver is in the programming mode:
Locking the doors
Unlocking the doors
7 Hold down the lock and unlock buttons on the transmitter until the remote control door lock receiver will respond in the following manner:
Locking the doors.
Unlocking the doors.
Repeat step 7 for each additional transmitter.
Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
Old Mar 9, 2013 | 02:20 PM
brown1243's Avatar
2 keyless fix pads 18.95
Old Mar 9, 2013 | 04:37 PM
db/sb's Avatar
Locking the doors
Unlocking the doors
Locking the doors.
Those instructions won't work on an HHR. Your S10 Blazer has a completely different security system.
Old Mar 9, 2013 | 05:30 PM
way2fast4u's Avatar
Key fob fix
Originally Posted by KChhrSS2008
Hi, was uo at the dealership and they said a new key FOB for my 2008 SS was $140 and $40 to install. That is ridiculous. Does anyone know who sells these for a cheaper price?
Thanks in advance!
Hi I had the problem and found a place on line that had a little plastic sheet that you lay in the printed circuit board and works great I will have to look up the wed sight
