Looking for door lock knobs
Well first you have to un-wind & remove the oem plastic knobs, Very Coarse thread. (rightee-tightee......Lefty loosee)
& in unlock position, trim the threaded stem, I trimmed mine to about level with door panel, Be careful not to bugger up the threads, or it will scrape out the plastic threads in the knobs.. Then wind them back on, Test & if need lower, tighten down more ( but gently)..
That's it..
& if you should bugger the threads, you could just use a glue for knob securement..
That's it..
Later
Allex
