Losing oil through exhaust
Old Jan 28, 2019 | 11:41 PM
  #31
they are low. Check post 22 by RJ.
Old Jan 29, 2019 | 07:38 AM
  #32
Ohiocruiser's Avatar
I am not a mechanic by any means, but the way I see it, that worn piston rings would create the conditions complete opposite of what i am having, by allowing all the blow by into cylinders and burning there. With all the blue smoke coming out of exhaust.
Old Jan 29, 2019 | 07:43 AM
  #33
Also watched some videos. And the guy in the video was talking about clogging catalytic with oil from bad turbo. That was the reason I replaced mine. Oil was coming out of exhaust. So my question is it possible that increased back pressure from exhaust would create excessive blow by in pcv sistem?????��
Old Jan 29, 2019 | 07:48 AM
  #34
Compression (pressure) pushes past the worn rings and into the engine block. That excess pressure then pushes the oil mist out of the block via the PCV system.
Maybe it's just the picture, but that valve on the catch can system does look like it is backwards. The arrow should point to the intake manifold because that's where the vacuum pull is.
Old Jan 29, 2019 | 08:08 AM
  #35
Cat Man HHR's Avatar
I don't think it is. By the pictures it's showing where the hoses start from leading towards the catch can that is connected to the vacuum source. That's my take on it. Better pictures or a schematic would definitely help.
Old Jan 29, 2019 | 08:12 AM
  #36
I will take better and more detailed pictures of it. And post it here. What about possible increased back pressure from exhaust? Can it cause that kinda problem?
Old Jan 29, 2019 | 08:17 AM
  #37
Thank you for explanation. If that is the case, that would be the first time I've ever heard all four cylinders loosing compression at petty much same rate.
Old Jan 29, 2019 | 08:26 AM
  #38
Yes, back pressure causes the engine to work harder which can make more crankcase pressure if the rings are bad. To much back pressure and the engine can't run. Potato in tailpipe syndrome.
Old Jan 29, 2019 | 08:30 AM
  #39
DrLoch's Avatar
Clogged cat also...
Old Jan 29, 2019 | 08:32 AM
  #40
It's hooked up to the intake manifold which is a vacuum source. That means the direction of flow would be into the manifold.
The other side of that valve goes to the catch can. The can is connected to the valve cover tube.
Still looks like the block valve is backwards or installed in the wrong place.
