Manual Headlight Control
Old Sep 22, 2006 | 11:33 AM
timrchat's Avatar
The lights come on when the wipers are on, but it doesn't seem to effect the dashboard lights, so it's hard to tell.
Old Sep 22, 2006 | 02:07 PM
Dave C's Avatar
fastsuv said "This is unlike any car I had before." But this is a good thing, right Steve ?
Old Sep 22, 2006 | 03:25 PM
Bornanoldsoul's Avatar
I have a question that somewhat pertains to this thread. Has anyone else had this happen? I turn on the wipers to intermitent and they come on, turn them up to the low setting and they SOMETIMES come on. Turn them to high and they come on. If I turn them from high back to low, then they usually come right on............also, when I hit the highbeams, there is a long pause. The first time it happened, I about wet myself! It doesn't usually have a long delay, just occasionally. Anyone experienced either of these? I already have to take it in for the clunk noise in the steering system and was just wondering if I should mention these too or maybe they're just normal........
Old Sep 23, 2006 | 03:26 AM
wheelsee's Avatar
When your turning to intermittent what speed are you going because our cars have speed sensitive wipers...
-wC
Old Sep 23, 2006 | 05:20 PM
Hi Wheelsee:)
The intermittent work fine, they have the delay at different speeds. The problem is when I change them from intermittent to low. Sometimes the low doesn't come on....at any speed. When I change them to high or back down to intermittent and then to low, the low will come on. It doesn't always do this, just occasionally. I have checked to make sure the fuses are seated properly and they all are..........wierd! I was just wondering if this was an issue with the HHR in general. Still love my HHR, just need to make friends with the Gremlins:)!!!
Old Sep 25, 2006 | 11:34 AM
  #26
wheelsee's Avatar
did you feed your intermittent gerbil?
Old Sep 27, 2006 | 02:09 PM
  #27
Damn, Knew I forgot something:)
Old Sep 27, 2006 | 02:18 PM
  #28
SoCalHHR's Avatar
Intermittent gerbils need love too!
Old Oct 2, 2006 | 07:25 AM
  #29
Went to the dealer last week to get the steering column problem fixed(clunking,GM put out a bulletin and specified part)......GM warehouse doesn't have it.....no local dealer has it........all on back order. Not sure what to make of that. Are alot of people having trouble or ?????
lithiumfun
Drivetrain (Excluding Engine)
Jun 12, 2014 11:22 AM
11hhrlt
Mods - Exterior
45
Apr 7, 2014 06:35 PM
hhrumadbruh
Oct 26, 2012 07:53 PM
Kookie
Feb 26, 2012 01:18 AM
Double0
"How To" Tutorial Library
Oct 12, 2011 04:34 AM
