Mass air flow sensor problem
Old Nov 10, 2017 | 10:34 AM
  #31
Jmck0020's Avatar
Was getting 0 volts at plug terminal E, but 5 volts lower down wire. So broken wire to plug. New pigtail, so far so good. Thanks for the info and help.
Old Nov 10, 2017 | 10:45 AM
  #32
Loose or broken wires are common, especially if a P.O. had installed one of those goofy power chips, with the scotch lock wire tap connections.
Old Nov 12, 2017 | 06:04 PM
  #33
Jmck0020's Avatar
Ok about 30 miles driven now. Still no return of the CEL. But I’m still having the rough shifting and slow acceleration. Almost as if it’s misfiring. Is this probably going to quit after a few more cycles, is the computer relearning or should I be concerned.
Old Nov 12, 2017 | 07:29 PM
  #34
You can try a lobotomy; disconnect the negative battery cable for a few minutes. That will clear any hidden codes.
ChevyM84
Apr 28, 2015 02:49 PM
artillery0811
Feb 20, 2014 05:40 PM
Randy08
2.2L Performance Tech
Jul 7, 2008 05:05 PM
808jrh
2.4L Performance Tech
Sep 21, 2006 05:50 PM
