From MPH to KPH?
I found a thread that said that you go through the personalization settings for the car to turn it to KPH. Is this just the distances of trips/total miles traveled, or does this ALSO make the speedometer work as if it was JUST KPH. So if I change it to METRIC, when I'm driving into Canada, the speedometer will work as if I bought the car in Canada where the 30 mark means 30 kph NOT 30 mph and whatever metric conversion THAT is (48 kph) So whenever I drive in Canada, all I have to worry about it changing that setting and it will adjust to kilometers per hour and I will just drive the posted speed limit, not worrying that I'm using a car with MPH that I use at home.
It also changes the speedometer calibration to km/h, the only drawback is that now it tops out at 120 km/h which is roughly 70 mph.
If you haven't already, give this thread a read for more info.
https://www.chevyhhr.net/forums/general-hhr-4/mph-kph-36734/
Being a Canuck I have the system set to metric when here in Canada and my speedo does not top out at 70 mph the numbers on the speedo do not change just the calibration of the speedo needle the other readouts show in metric like trip , litres per 100 klms temp gauge in celcius.
He meant that the speedo tops out at 120 kph (roughly 75 mph) when set to metric. If you go faster than that you won't have any indication of your actual speed.
This brings up an interesting question, will a canadian cluster going up to 220, when switched to mph acutally read up that high? hmm....
Attachment 14879
