From MPH to KPH?
Old Jul 2, 2013 | 06:55 PM
db/sb's Avatar
I know it's not exactly what you all are talking about, But here is the RPD display on my SS when I did the mph/kph switch. (And a bad edit by me trying to change the k to a m.)
Attachment 14879
They tell me that my GTO will go that fast and faster....I'll take their word for it.
Old Jul 3, 2013 | 05:27 PM
ecopower ss's Avatar
Yes in canada our cluster go to 220 mph when i turn it to english.The positive is that the boost turn from kpa to psi, power from kw to hp and torque from nm to feet lbs.The negative side of this is that the needle going up very slowly on a 220 mph speedometer.....
Old Jul 5, 2013 | 02:11 PM
wnyhhr's Avatar
Thanks a ton! This really helped out. Now I just have to set it when I cross the Peace Bridge ( or Rainbow Bridge, depending on where I'm specifically going) into Ontario!
Old Jul 6, 2013 | 11:44 AM
This is way off topic, but do you need a passport to cross the Canada/US border?
Old Jul 6, 2013 | 01:12 PM
Radco's Avatar
Yes you need a Pass Port now.. You can also get a Pass Port Card, slips in your wallet, But it has some restrictions with the card vs the pass Port.. Cannt remember what is was or is!
Old Jul 6, 2013 | 02:18 PM
I was thinking about getting a passport for spurious needs, until I found out how much it would cost, over $200. I don' need it that bad, only had a possible use once in 20 years.
