New to HHR - discovered 2 things
Old 12-13-2017, 05:57 PM
treff-7's Avatar
Hi all,
I bought an HHR a few months ago and since I discovered 2 interesting things. I just want to confirm that they are normal.
1. When the cabin air is set to blow on your feet only, the air cannot be recirculated inside the cabin. The light for the outside button flashes if you push the one for the recirculation.
2. If you set the air to be recirculated in the cabin and turn the fan on the A/C turns on as well. The A/C light will not illuminate but I can clearly hear the A/C clutch engage and also feel it on the engine. This happens even if the air is set to hot.
I forgot to mention that I have a 2007 2LT 2.4L manual.
Thanks!
treff-7 is offline
Old 12-13-2017, 07:24 PM
Yes, this is all as designed. Also the compressor will run if defrost is selected.
RJ_RS_SS_350 is online now
Old 12-13-2017, 09:46 PM
Confirmed!
Welcome to the site!
Oldblue is offline
Old 12-14-2017, 09:40 AM
treff-7's Avatar
Good to know! Thanks guys!
treff-7 is offline
Old 12-14-2017, 09:44 AM
It’s always a fun thing to discover new things about a new to you ride, if you didn’t get an owners manual Donbrew has a link in his signature to them on line.
Oldblue is offline
Old 12-15-2017, 12:22 AM
treff-7's Avatar
Thanks oldblue!
I have an owners manual. I actually need to go through it to see if it says how to register a new key fob. The car only came with one and a spare would be smart to have.
treff-7 is offline
Old 12-15-2017, 12:29 AM
Welcome.
Original GM fobs unfortunately have to be set up by a dealer or locksmith using special tools. However there are aftermarket ones available that you can program yourself.
Check out this thread - https://www.chevyhhr.net/forums/prob...grammer-59484/
whopper is offline
Old 12-15-2017, 03:56 PM
treff-7's Avatar
Thanks whooper!
Bummer. I guess I only need to buy the dorman one once and the programmer will work for all fobs in the future.
treff-7 is offline
Old 12-15-2017, 07:14 PM
The Dorman unit has a limit I believe.... Maybe 4 fobs?
whopper is offline
Old 12-15-2017, 07:17 PM
And 3 sessions. The 4 fob limit is in the car, not just a Dorman thing.
Quick Reply: New to HHR - discovered 2 things
