and now Gas leak
Old Jul 10, 2018 | 09:26 PM
SwaintaN's Avatar
Andrew will be back from Vacation this weekend, then hes checking for the gas smell... the inside of the car while driving stinks of gas, so gonna drive excursion till then.
Fuel gage, i watched her put in gas, i did the math, the dash had the right level and digital amount... But park in the drive on the "hump" which raises the passenger side of the car in the air... Then the Gage says E.
Old Oct 16, 2019 | 08:55 PM
hhr06NJ's Avatar
gas odor
10/2019 yes, the fuel line corrodes in front of left rear wheel. There is a clip that holds the line, and water gets trapped, and corrodes the line. A Tech, cut 6 inch piece out, had to bend new piece slightly with a pipe bender, added a couple of ferrules and brass nuts now good as new.
fairly common problem
30 minute repair. (like a brake line repair)
Old Jan 16, 2020 | 08:21 AM
LjinTucson's Avatar
Smells of gas
Originally Posted by SwaintaN
Ok, so noticed it earlier in the day that i smelled gas while kiddo was swapping batteries. but didnt see a drip or anything on the ground.
put gas in, drove to watch the fireworks, man o man, rear driver side tire you can smell gas really strong, buddy climbed under and cant find it dripping.
so we said screw it, watched the fireworks went back to the car and opened the hatch, and BAM in the face is strong gas odor.
so where would you guys start inspecting?
I have read that if you fill the gas tank to full this is the problem the other problem could be the gas cap is just old and not sealing properly. I just purchased my HHR yesterday 01/15/2020 I filled it up and it smells of gas my entire garage I had to open the garage before I started it just to make sure I didn't blow up the place.
checked for leaks non found.
Old Jan 16, 2020 | 09:50 AM
Hi Lj, to the forums!
Read this thread again, your problem is much more likely to be a leaky vapor line.
Old Jan 16, 2020 | 12:04 PM
Welcome to the site, Read here,
https://www.chevyhhr.net/forums/how-...follies-62310/
the fuel lines are most likely the source of the smell of fuel in your garage.
not very expensive or hard to replace them front to back
Old Jan 18, 2020 | 10:39 AM
SwaintaN's Avatar
Havent really dived into it much more. But I did find rubber hose, connected to the metal lines. This was in front of rear driver tire. Along with when I was doing all the work to it, i noticed the rear driver wheel well was taking off (missing the pins to hold it in, so i replaced em).
Side note, when the local dealer fixed the recall EPS and pulled forget to hook a sensor back up.. It did leak gas then... I think it was the MAF sensor that they left unhooked; but that is the ONLY time ive seen actual gas leaking.
Old Oct 15, 2023 | 08:56 PM
SwaintaN's Avatar
Was both fuel lines, tucked up above exhaust, near rear driver side tire.
Replaced with ss braided plug n play lines. Mpg is better now to.
Old Oct 22, 2023 | 03:28 PM
PulpFriction's Avatar
Good to know it was solved. Appreciate the follow-up. Hope you didn't really wait three years to fix it, lol.
No surprise it was the lines. Pretty common. Absence of drip was probably because the black insulators that caused the corrosion in the first place were soaking up the fuel long enough for it to evaporate.
A friend was working on an HHR with the same symptoms. He was shocked that I (1) predicted the problem with pinpoint accuracy, and (2) had a kit on hand to fix it.
Amazing what a noob like me can learn in these forums.
Old Oct 22, 2023 | 03:31 PM
SwaintaN's Avatar
No didn't take years. Just didn't post much for a while, went though alot of personal things, sons death, brother death, nut house etc....
Yea the insulators they use attract water plus someone did a crap patch job then wrapped it in cheap flex heat shield.
Old Oct 23, 2023 | 08:26 AM
I wonder what the dealer mechanic was doing under the hood doing the EPS recall. Nothing besides the fuse under there.
