It worked for me either way the dealership should be doing this once the oil & filter have been changed its part of their routine check. I always check before I leave the to ensure they did it just to make sure that they did do the work!
Better still maybe you should be pulling the dip-stick & seeing if the oil is full & clean & oil cap is back on..
I prefer to do my own stuff.. This way I know who to blame..
reset: I have always done the 3 pedal depress with key on, just like Mopars do.. No problems..
So many people seem to have problems when someone else changes thier oil. I just can't see trusting someone else to do such a simple task. It is just barely above putting gas in the car.
