Oil Life....???
Originally Posted by 1BadPig
To reset the CHANGE ENGINE OIL SOON message, do the following procedures:
1. Turn the ignition to RUN, with the engine off.
2. Press the information and reset buttons on the DIC at the same time to enter the personalization menu.
3. Press the information button to scroll through the available personalization menu codes until the DIC display shows OIL-LIFE RESET.
4. Press and hold the reset button until the DIC display shows ACKNOWLEDGED. This will tell you the system has been reset.
3. Turn the key to LOCK.
Does that reset the oil life percentage or just get rid of the change oil soon message?
UPDATE!!
OK. I've tried every possible combo and still cannot get into personalized menu.
About the only thing I'd need to do would be to reset the dang oil life monitor when the techies forget to do so or if/when I do some driveway maintenance.
So, here's the trick. Turn ig to run, with engine off tap gas pedal to floor 3 x's. You should see it reset to 100%. This procedure is used for vehicles w/o the DIC interface. I would imagine the change soon would also go away.
Still gotta wonder how to get into personalized menu using sterring wheel buttons.
