Oil Life....???
Old Nov 30, 2005 | 09:28 AM
endeavorc's Avatar
Originally Posted by 1BadPig
To reset the CHANGE ENGINE OIL SOON message, do the following procedures:
1. Turn the ignition to RUN, with the engine off.
2. Press the information and reset buttons on the DIC at the same time to enter the personalization menu.
3. Press the information button to scroll through the available personalization menu codes until the DIC display shows OIL-LIFE RESET.
4. Press and hold the reset button until the DIC display shows ACKNOWLEDGED. This will tell you the system has been reset.
3. Turn the key to LOCK.
Thanks for the SBS 1BadPig, at work so didn't have a chance to post it
Old Nov 30, 2005 | 09:33 AM
1BadPig's Avatar
Does that reset the oil life percentage or just get rid of the change oil soon message?
It should do both... if the HHR DIC is anything like my Avalanche. I figure if the oil life is at 100% there is no reason for the message to come on.
Old Nov 30, 2005 | 09:52 AM
captain howdy's Avatar
Good point, thanks. I still want to know about the oil filter itself. I guess I'll just go out and look at my engine to see if I can answer my own question.
Old Dec 18, 2007 | 11:44 AM
ilgallo's Avatar
with ig turned to run, info/reset don't do squat for me. does not go into personalized menu. any ideas????
Old Dec 18, 2007 | 12:27 PM
solman98's Avatar
Wow, 25 month old thread.
Id you can't figure it out by the manual, do a search. There is a shortcut methods someone posted. The Normal method always works for me.
Old Dec 18, 2007 | 12:34 PM
Snoopy's Avatar
Read your Owners Manual, there is an explanation on the correct procedure (the buttons need to be pushed in a "secret" combination....kind of like a Captain Video ring)
Old Dec 18, 2007 | 12:52 PM
ilgallo's Avatar
tx. i'll bring my decoder ring with me next time. just hope it doesn't decypher as 'Eat more Ovaltine'!!!!
Old Dec 19, 2007 | 10:52 AM
ilgallo's Avatar
Exclamation
UPDATE!!
OK. I've tried every possible combo and still cannot get into personalized menu.
About the only thing I'd need to do would be to reset the dang oil life monitor when the techies forget to do so or if/when I do some driveway maintenance.
So, here's the trick. Turn ig to run, with engine off tap gas pedal to floor 3 x's. You should see it reset to 100%. This procedure is used for vehicles w/o the DIC interface. I would imagine the change soon would also go away.
Still gotta wonder how to get into personalized menu using sterring wheel buttons.
Old Dec 19, 2007 | 04:03 PM
gravett1's Avatar
Smile
Hold both buttons until the menu comes up it takes a few seconds
Old Dec 19, 2007 | 05:10 PM
oneton's Avatar
WOW ! It's not this hard to do ! About 15sec. to do
Snoopy,I have a Captain Video ring thats why its so easy
