Operating Temp
Old Mar 14, 2010 | 05:39 PM
blumet27's Avatar
Operating Temp
2007 2.2 HHR
Cooling System
What are the normal operating temperatures?
What is the highest temp I should see?
Can someone post the temps for all engines and models.
Old Mar 14, 2010 | 06:15 PM
J W Davis's Avatar
I have never seen the temp below 200 after warmup, nor above 215 after driving in Texas for 49k miles in 2.5 years. That's just mine, however to each his own.
Old Mar 14, 2010 | 07:03 PM
urbexHHR's Avatar
While idling through a parking garage, the highest I've ever seen is 220... But I'm in Michigan. Usually it's around 187 or so for me.
Old Mar 14, 2010 | 09:17 PM
Old Lar's Avatar
2.4L runs 196 or so. The highest I've seen has been 220, when stuck in traffic in the summer. The fan kicked on and the temp dropped back to 196.
Old Mar 14, 2010 | 09:22 PM
davidjb's Avatar
mostly 194 have seen 205
Old Mar 15, 2010 | 01:46 AM
biglefthhr's Avatar
194 to 196 on the hwy and 217 in traffic, then the fan kicks on and drops it down to 194
Old Mar 15, 2010 | 06:50 AM
pitbull76's Avatar
My 2.0 SS will often see 212-214 in normal operation. It runs hotter than my old 2.4. The 2.4 usually was right around 200 in normal operation; The highest I ever saw the 2.4 was near 220 once when towing a small trailer with the A/C on and a nasty headwind.
Old Mar 15, 2010 | 10:23 AM
terryk's Avatar
Well, the hotter the better for MPG to a point. My SS runs 190-200 and I have seen 215 sitting at a long light. I don't care until about 230 and then I will pay attention to what direction it's taking. I hear the fan kick on so it's doing it's job. Unloaded the temps seem to be well managed by the fan. We will see when I am climbing the mountains in 100F weather. As long as it stays under 230 I am fine with it.
I did notice that the upper radiator air deflector/baffle that is intended to force air through the radiator and not over it lays back enough that incoming air can get past it to the engine. It looks like it supposed to have something to seal it at the top but nothing is there.
Maybe GM decided they wanted some air to pass into the engine compartment unheated by the radiator. I guess I should look at the manual and see what they intended. There are a couple of gaps that would allow air around the radiator. (Edit: I check the manual and I guess this is normal. I'm going to stop by the dealer and check out another SS to make sure.) I need to make sure the air dam is there too.
Old Mar 19, 2010 | 12:30 AM
StaticAZ's Avatar
According to the temp gauge on my 2010....it's running between 180º-190º
Old Mar 19, 2010 | 09:18 PM
IgottaWoody's Avatar
184 - 204 .... 08 ss
