Outside Temp Gage - Accurate? :)
My temp gage is always cheating at least 5 degrees high and some days I swear 10 degrees. Does anyone know where the sensor is for this? I hope it isn't the same as the headlight sensor on the dash!
Does anyone know how to adjust this?
I'd love your two cents.
The weather forecast temperature is always different from the road surface temperature. Road surface temp is usually higher, and is the real temperature you feel, I guess the sensor measures the real temp.
I am going from my gage on my back porch, 20 feet away from my HHR!
It consistently shows 5 degrees higher. I understand that the pavement is going to be hotter - that is why I was wondering where the temp sensor is!
Here is the location on the HHR https://www.chevyhhr.net/forums/show...sor#post237100
i like the ice on road warning
